Stackwise Configuration best practice
znaqvi@intervision.com
Frequent Visitor
Frequent Visitor
I'm currently converting single 3560G Access switch with 2 x 2960X switches with Stackwise cable.
Uplink to the distribution switch will remain same which will be connected to a single 2960X.
Can someone tell me the migration best practice from 3560G to 2x2960X?
Leo Laohoo
Copy the config and paste it to the 2960X.
Leo Laohoo
So copy the configuration from 3650G and past the same configuration to both 2960's ?
Correct. Make sure you change the interface details. The 3560 uses "Gi0/<PORT>" while the 2960 stacked uses "Gi <SLOT>/0/<PORT>".
