SFE/SGE L3 functionality
rudydekeninck
Hello;
Is statich L3 configuration (e.g. intervlan routing) supported on a stack of SFE/SGE switches? If so, L3 failover is provided when the stack rolls over from the master to the backup master?
Also, I am wondering whether any support for VRRP (or even HSRP) is either supported or planned for a feature SW release?
Thanks a lot and best regards
Rudy
Ganesh Hariharan
Hello;
Rudy
Hi Rudy,
Check out the below link for configuring intervlan routing in 3750 stacked switches,
http://www.cisco.com/warp/public/473/intervlan3750_45002.pdf
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
