Difference B/W MST & CST -Reg
Dear All,
Can anyone tell me the explanation for my questions.
1.What is the use of MST?
2.Difference B/W MST and CST and RSTP?
3.Other than Convergence, is there any advantage for RSTP over STP?
4.Which protocol  i have to prefer if other end will be D-Link Switch?
Thanks in advance.
Senthil
Hitesh Vinzoda
Level 4
Level 4
          MST is used when you want to have separate instances of STP for different Vlans or set of Vlans.
                    e.g.      MST 0 = Vlan 1,2,3,4
                                MST 1 = Vlan 5,6,7
They maintain different set of blocked and forwarding ports per MST instance, so if one trunk port may be blocked for MST 0 while it could be forwarding for MST 1.
          CST is one STP domain for all Vlans ( so called as Common Spanning Tree protocol)
          You have luxury of using Uplinkfast and Backbone fast with RSTP
     RSTP, PVST, RPVST+, MST all are backward compatible with STP.
so if you run STP on Dlink and RPVST on Cisco switch, its backward compatible but the Dlink will block port for every Vlan and will have single STP domain while Cisco can have different STP domain as configured
Hitesh Vinzoda
Please rate helpful posts
