%SFF8472-3-THRESHOLD_VIOLATION: Twe2/0/2: Rx power low warning
broow
I have noticed these errors on both Cat9500 we have upgraded from cat9k_iosxe.16.11.01.SPA.bin to a new IOS.
Any ideas?  did not have these errors before.
Switching, LAN Switching
Mohsin Alam
Try cleaning or replacing the fiber as the SFP is having low RX ( receive ) power.
You can share the output of show int tw2/0/2 trans de
## Make sure to mark post as helpful, If it resolved your issue. ##
marce1000
 >...we have upgraded from cat9k_iosxe.16.11.01.SPA.bin to a new IOS
                   If not seen before , usually then it's a software bug.
 M.
_a_techie_
Hello @broow ,
Is it just a single switchport that complains about RX power? If so, try replacing the cable and see if that makes a difference.
If you are getting the same alert for multiple switchport, then it would be a software bug like @marce1000  pointed out.
