SFP-10G-SR with Multi - Mode Fiber?
Patrick McHenry
Level 4
Level 4
Can I use the SFP-10G-SR 10g interface woth Multi - Mode fiber?
Thanks, Pat.
3 Accepted Solutions
Reza Sharifi
Yes, SR in the part number stands for short reach and that is used with multimode fiber.
If you had SFP-10G-LR (long reach) than you would have to use single mode fiber.
SFP-10G-SR Multimode fiber
SFP-10G-LR Single Mode fiber
Ganesh Hariharan
Thanks, Pat.
Hello Pat,
Yes You can check out the below link from cisco
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/data_sheet_c78-455693.html
Hope to Help !!
Ganesh
answanso
Hi Pat,
As mentioned above SR does in fact indicate MM fiber. Make sure you utilize lazer-optimized fiber (50 micron OM3/OM4). Using 62.5 micron decreases usable distance and in some cases does not work at all.
Anthony
Reza Sharifi
Old Thread, but I had the exact opposite question -
Can you use Single Mode Fiber with a SFP-10G-SR ?
Ganesh Hariharan
Thanks, Pat.
Hello Pat,
Hope to Help !!
Ganesh
answanso
Hi Pat,
Anthony
