SFP Compatibility betwen SMB and Catalyst Switch
Adan Correa
I'm creating a network design, I need to confirm wich SFP i can use to interconnect  a SG350-28SFP with MGBLH1 transceivers to a switch Catalyst 3850-XS
The objective to fulfill is that the fiber link betwen both switches supports up to 40km.
6 Replies 6
acampbell
To support up to 40KM on the 3850-XS you will need a GLC-EX-SMD SFP.
More info can be seen here:-
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/gigabit-ethernet-gbic-sfp-modules/product_data_sheet0900aecd8033f885.html
Regards, Alex. Please rate useful posts.
Hi acampel,
thank you for your answer, but i have a doubt if GLC-EX-SMD is compatible with the SFP for SMB MGBLH1.
Where i can validate it?
I have this documentation, but it does not indicate compatibility between GLC-EX-SMD and MGBLH1
https://community.cisco.com/t5/small-business-support-documents/interconnect-cisco-sb-switch-and-catalyst-switch-with-sfp/ta-p/3146234
Hi Acampbell,
I can use GLC-LH-SMD SFP for SG350-28SFP Switch ?
Yes - this SFP is compatible the SG350 range
350 Series
SG350GLC-LH-SMD1 GbpsSFP550mDuplex FiberMMFLCOptic-5 to 85CY2.3.5.63
GLC-LH-SMD1 GbpsSFP10kmDuplex FiberSMFLCOptic-5 to 85CY2.3.5.63
Hi acampbell,
I see 2 Copper ethernet port on SG350-28SFP-K9-EU switch. They are port 10/100/1000 type ?
Refer below link to check the compatibility of the modules.
https://tmgmatrix.cisco.com/
