Showing results forĀ
Search instead forĀ
Did you mean:Ā
SFP+ Compatibility with Nexus 3065-x
etienne99
I need to know if the STP-SFP+-LR Wavelenght 1310 10km  from other venders will be compatible with the Cisco Nexus 3065 switch. I know you can run
switch(config)# service unsupported-transceiver
switch(config)# no errdisable detect cause gbic-invalid
My question is will it work?
Thank you
Etienne
Leo Laohoo
From other vendors?  No it won't.
You can use those two hidden commands but any troubles with your 3rd party SFP+ will not be supported by TAC.
The reason is because there have been numerous well-documented cases where the 3rd party modules (not made by the big five) is the root of (or part of) the problem.
