SFP for most usable types of fibre?
Photogregor
I've got to ship two SG200-26 to a branch to connect to connect two floors. These floors are connected via fibre optic. But there up to now is no technician at this location so I don't know which type of fibre it is (SM, MM, 50 or 62,5). And I want to prepare everything as soon as possible. Is there any kind of SFP device for this switch, which is feasible for all kinds or which at least covers the most usable types of fibre?
Stefano
Mark Malone
if you were using catalyst I would say your using multi-mode due to the distance not single and if its multi-mode its most likely lc-lc om3  but your using smb switches which are not that standard compared to the glc-sx-mm the closet I can see would be the MGBSX1
GLC-SX-MM=
1000BASE-SX SFP transceiver module for MMF, 850-nm wavelength, dual LC/PC connector
http://www.cisco.com/c/en/us/products/collateral/switches/small-business-200-series-smart-switches/data_sheet_c78-634369.html
Table 4.       MFE and MGE Transceiver Ordering Information
Product Ordering Number
Description
MFE Transceivers
MFEBX1
100BASE-BX-20U SFP transceiver for single-mode fiber, 1310 nm wavelength, supports up to 20 km
MFELX1
100BASE-LX SFP transceiver for single-mode fiber, 1310 nm wavelength, supports up to 15 km
MFEFX1
100BASE-FX SFP transceiver for multimode fiber, 1310 nm wavelength, supports up to 2 km
MGE Transceivers
MGBBX1
1000BASE-BX-20U SFP transceiver for single-mode fiber, 1310 nm wavelength, supports up to 10 km
MGBLH1
1000BASE-LH SFP transceiver for single-mode fiber, 1310 nm wavelength, supports up to 40 km
MGBLX1
1000BASE-LX SFP transceiver for single-mode fiber, 1310 nm wavelength, supports up to 10 km
MGBSX1
1000BASE-SX SFP transceiver for multimode fiber, 850 nm wavelength, supports up to 500 m
Mark Malone
GLC-SX-MM=
Description
MFE Transceivers
MFEBX1
MFELX1
MFEFX1
MGE Transceivers
MGBBX1
MGBLH1
MGBLX1
MGBSX1
Photogregor
Good answer, now I know what I have to consider. Thanks a lot.
