SFP module compatibility with 10G network module
Beaurr
I want to buy 9200 switches witth 10G network module (x 4).
Are 1G SFP compatible on 10G modules? because, in a first time, i will only have 1G SFP
Reza Sharifi
Yes, this module supports both 1 and 10Gig
C9200-NM-4X    4x 1G/10G network module
5 Replies 5
 Mind the model. Depending on the model, yes,you can have that:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-cat9200-ser-data-sheet-cte-en.html#Featuresandbenefits
C9200-48PXG
48 ports full PoE+ (8 mGig ports up to 10G, 40 ports up to 1G)
thank you!
Reza Sharifi
Mark Elsen
           - For SFP-compatibility use this app : https://tmgmatrix.cisco.com/
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
C9200-NM-4X (=) - they are SFP+ i guess, so it is compatable for both as you mentioned.
BB
