SFP module (GLC-SX-MMD) from existing Cisco 3750X switch
1.I wanted to know that existing Fiber module(GLC-SX-MMD)from Cisco 3750x, Will it support to Cisco WS-C3650-48PD-L and WS-C3850-16XS-E switch.
Can you leverage existing fiber module WS-C3850-16XS-E to Cisco Cisco WS-C3650-48PD-L and WS-C3850-16XS-E switch.
2. Cisco LAN Controller is going to connect with two Distribution switch in network, so what would be the best solution to connect WLC in network
Mark Malone
the SFP is supported as below
Use a portchannel between the 3 switches if possible if the dist switches are stacked VSS or VPC
  Transceiver Description Software Release
Network Device Product ID Transceiver Product ID Data Rate Form Factor Reach Cable Type Media Connector Type Transceiver Type Case Temp DOM HW Capable Minimum DOM SW
WS-C3850-48XS GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 3.7.2E IOS XE 3.7.2E
GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 16.2.1 IOS XE 16.2.1
WS-C3850-48XS-S GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 3.7.2E IOS XE 3.7.2E
WS-C3850-48XS-E GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 3.7.2E IOS XE 3.7.2E
WS-C3850-48XS-F-S GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 3.7.2E IOS XE 3.7.2E
WS-C3850-48XS-F-E GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 3.7.2E IOS XE 3.7.2E
WS-C3850-24S GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 3.3.3SE IOS XE 3.3.3SE
GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 16.1.1 IOS XE 16.1.1
WS-C3850-12S-S GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 3.3.3SE IOS XE 3.3.3SE
WS-C3850-12XS GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 3.7.1E IOS XE 3.7.1E
WS-C3850-16XS GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 3.7.1E IOS XE 3.7.1E
WS-C3850-24XS GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 3.7.1E IOS XE 3.7.1E
WS-C3850-32XS GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 3.7.1E IOS XE 3.7.1E
C3850-NM-4-1G GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 3.2.0SE IOS XE 3.2.0SE
C3850-NM-2-10G GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 16.1.1 IOS XE 16.1.1
C3850-NM-4-10G GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 16.1.1 IOS XE 16.1.1
C3850-NM-8-10G GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS XE 16.1.1 IOS XE 16.1.1
C3750X
WS-C3750X-24T GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS 12.2(53)SE IOS 12.2(53)SE
WS-C3750X-48T GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS 12.2(53)SE IOS 12.2(53)SE
WS-C3750X-24P GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS 12.2(53)SE IOS 12.2(53)SE
WS-C3750X-48P GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS 12.2(53)SE IOS 12.2(53)SE
WS-C3750X-48PF GLC-SX-MMD 1 Gbps SFP 1km Duplex Fiber MMF LC Optic -5 to 85C Y IOS 12.2(53)SE IOS 12.2(53)SE
