07-01-2015 06:48 PM - edited 03-08-2019 12:48 AM
Hi All
I configured Cat 4507 with 2 sup and 2 48 port UTP modules
the sup module nclude for SFP ports 2-10G and 2-1G
I inserted 2- compatible SFP in the 2-10G port of both SUP but only one SFP from each SUP can operate and the other SFP returned an eeror that the SUP can not support the SFP with power ?
could i fix that ??
Solved! Go to Solution.
07-01-2015 07:36 PM
WS-X45-SUP7L-E non blocking for both 10 G and 1 G and IOS is Cisco IOS® XE Software, the modular open application platform for virtualized borderless services with the full feature set of Cisco IOS Software Release 15.0SG |
also we use
| SFP-10G-SR |
07-01-2015 07:15 PM
What is part number for the sup?
07-01-2015 07:36 PM
also we use
| SFP-10G-SR |
07-01-2015 07:45 PM
When you have 2 sups in the chassis, you can only use one of the 10Gig ports in each sup.
have a look at table-2 in this link:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-4500-series-switches/data_sheet_c78-686325.html
07-02-2015 09:18 PM
so, o any solution for this problem
I have 4 10Gbps uplinks must work with all BW 40 Gbps
shall I need to buy anothe 10G module ? or any upgrade or update can be used?
07-02-2015 09:41 PM
High-Availability and Uplink Options for Supervisor Engine 7L-E in Dual Supervisor Engine Mode
2-
Yes you need to bug another module (line card) which support 10Gp.
