08-26-2022 05:04 PM
Hello Everyone,
I have a question regarding the 2 types of SFP:
SFP-10G-SR vs. SFP-10/25G-CSR-S
Scenario:
Current in production: Cisco Catalyst 4500X have some SFP 10G, type: SFP-10G-SR; these ports are connected to various devices like routers, switch, servers etc.
I am in the process of upgrading the 4500X to 9500 Catalyst, but with a newer SFP type: SFP-10/25G-CSR-S.
My concern: Will the newer SFP-10/25G-CSR-S automatically negotiate and default to 10G Speed? or I will have to manually set the speed of the SFP-10/25G-CSR-S ports to 10G to make it work.
The reason I couldn't do the testing is because the 4500X are in production line now.
Thank you all in advance!
Byme88
08-26-2022 06:17 PM
One of the testing I have done same as yours :
I have a new Cat 9500 having Cisco SFP-10/25G-CSR-S and Traditional Stack Cat 3850 or other devicess have SFP10G-SR or SR-S did not work even with latest 17.3.5
Cat 9500 Cisco SFP-10/25G-CSR-S to Cat 9300 Cisco SFP-10/25G-CSR-S works as expected.
If you have latest Family of devices Cat 9K all over, then worth buying Cisco SFP-10/25G-CSR-S both the sides.
If you still looking to connect any OLD Modules does not support Cisco SFP-10/25G-CSR-S, then suggest to use 10G-SR
Note : this is my test outcome may be 6months+ old, this may be changed (not that I see any one have success).
08-26-2022 06:22 PM
Thanks so much for your response.
In this case I might be able to re-use the SFP-10G-SR from the 4500X. The trick question is: Will the newer switch 9500 support the old SFP-10G-SR????
By me88
08-26-2022 06:34 PM
yes they do support 100% on new Cat 9500/9300 - at least you save cost here.
08-26-2022 06:44 PM
Do you happen to know if the Cisco Nexus 5596 support SFP-10/25G-CSR-S?
byme88
08-26-2022 06:47 PM
Nexus running 7.X on Nexus 7K and 5K did not work for me.
check compatibility :
08-26-2022 08:59 PM
Did you know why it did not work ?
08-27-2022 01:36 AM 08-27-2022 06:04 AM 更新
Never put my time to investigate(honestly) - especially when we working in a production environment - more focus on working solutions rather deep diving into the root cause.
Maybe if I get a chance next will try if the time permits.
08-27-2022 04:47 AM
Agree, if you find, please post, that’s seems like something that should work without any issues.
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
