SFPs that is compatible with specific switch
Vencola
Hi everyone,
I have 3 switches, 6500, 4500, 3700 series, is there anything that can tell me what are all the SFPs types that are compatible with these switches.
I need to know if the SFP will be compatible before buying it + all the compatible SFPs.
Best regards.
Leo Laohoo
balaji.bandi
start from here you get all the information (this provide only cisco SFP ) not 3rd party.
https://tmgmatrix.cisco.com/
BB
Joseph W. Doherty
BTW, as SFP support varies by platform, port and IOS versions, you might not find "one size fits all" SFP transceivers.
Also if your try 3rd party SFPs, understand the meaning of lack of Cisco support and insure 3rd part vendor has 100% refund policy if found their SFPs don't work for you.
