12-10-2017 09:22 PM - edited 03-08-2019 01:03 PM
as i read SG300-52 doesnt support VTP but does anyone knows where it is written officially by cisco that it doesnt?
Solved! Go to Solution.
12-11-2017 12:30 AM
tHi
he reason it doesn't support it because it has another similar protocol GVRP that does same thing
Its in the admin guide that this is what is used for passing vlans , the whole smb range supports GVRP instead of VTP ,VTP is purely on catalyst switches
GARP VLAN registration protocol (GVRP) allows devices to dynamically exchange VLAN configuration information to make configuration of VLANs easier. When the switch receives VLAN information through GVRP and GVRP Registration, the receiving interface joins that VLAN. If an interface attempts to join a VLAN that does not exist and Dynamic VLAN creation is enabled, the switch automatically creates the VLAN.
12-11-2017 12:30 AM
tHi
12-11-2017 08:36 PM
no i just need a document where cisco says SG-300 52P doesnt support VTP for a customer
12-11-2017 09:11 PM
