SG300 no switchport command (requires help)
M R B
I have SG300 28 port switch which is in L3 mode
I have 3 vlans
vlan 30  IP address 10.10.30.1/24
vlan 40  IP address 10.10.40.1/24
vlan 50 IP address 10.10.50.1/24
I have fortigate firewall in 172.16.1.200
inter vlan routing is working perfect
when I try to make interface  gigabit port 28 as no swichport
it throws incomplete command error
options available are
access
customer
default-vlan
forbidden
general
mode
private-vlan
protected-port
trunk
which one should I take to assign an IP so I can give a default route to the 172.16.1.200
please help to find the correct option
thanks
7 Replies 7
Seb Rupik
Hi there,
The SG300 does not support routed interfaces.
Create another VLAN and SVI in the 172.16.1.0 /24 subnet and configure gi28 to be an access port in that VLAN.
cheers,
Seb.
Dear Seb Rupik
thanks for your quick response
I have created the vlan 100 and the interface vlan 172.16.1.1
assign port 28 to vlan 110
and gave default route as my firewall
but cannot ping the firewall or internet is not working
need your assistance
MRB
Hi there,
Is your firewall interface adding VLAN tags to the frames leaving it, or does traffic leave untagged?
Can you share the running config of the SG300.
cheers,
Seb.
Dear Seb Rupik
please find attached SG300 Config,
i forgot to mention vlan 20 which is a voice vlan coming form another switch which is managed by my service provider.
locally ip phones are working fine with the current config
issues is unable to ping 172.16.1.230 which is my firewall gateway
thanks for your assistance
MRB
I can check that your switch configuration is ok But you may be missing routes to add on FortiGate to local LAN.
Login to FortiGate and Network --->Routes--->Static Routes>
Destination Subnet: 10.10.30.1 255.255.255.0
Interface: LAN (LOACL)
Destination Gateway: 172.16.1.1
Same you can configure for all rest VLANs.
I hope that your FortiGate IP as:
172.16.1.230
If not then change the default route the switch also.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
As Deepak say, but it would be prudent to add a static routes on the fortinet for all of your subnets which are routed on the SG300:
ip route 192.168.2.0 255.255.225.0 172.16.1.1
ip route 10.10.30.0 255.255.225.0 172.16.1.1
ip route 10.10.40.0 255.255.225.0 172.16.1.1
ip route 10.10.50.0 255.255.225.0 172.16.1.1
I've never configured a Fortinet, but you will need to have a look at the NAT ACL it has configured and ensure that it captures all of your internal subnets.
cheers,
Seb.
THanks to all
its working fine after the static routes
