CISCO 4331 with Data License
ibegbu.david1
Hello Fam,
I have a client who ordered for the above device. While trying to make my order, i got confused on what data license means.
Please can someone help me with the meaning and the role it plays.
ibegbu.david1
I have checked apps.cisco.com website and i couldn't find the data license there. Is it that it comes by default?
Have a good look at the ISR4000 data sheet.
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/datasheet-c78-732542.html
Table 2 gives references to licenses
and again from tble 5 onwards.
The router arrives with an IP-BASE licence as default.
You need to know what additional features you want in order to select a different license.
For example- if you aim to run your router as a CUCME (Claa Manager Express)
you wil need to upgrade to a Voice License which expands (includes) the deafult IP-BASE
Voice (V)
 IP Base + Unified Communications: Cisco Unified Communications Manager Express, Survivable Remote Site Telephony (SRST), CUBE
Hope this helps
Regards, Alex. Please rate useful posts.
