SG300 Static Routes are not Delete/Editable?
stownsend
Level 2
Level 2
I have a Routing issue with one of my SG300-28P units. It has several Trunked VLANs.
I think I habe Narrowed it down to a Default Route on the offending SG300 though I cannot see to change or delete any of the Static Routes on the unit.
I can Add Routes with no issues, but once Added I cannot Edit or delete them.
Here is an Image of the working unit and an image of the non editable unit.
http://i.imgur.com/FmFIZvP.jpg
stownsend
Level 2
Level 2
Its not Fixed, though I was able to Change the Gateway IP Address.
I Saved the Config, Edited it to Include:
no ip route 0.0.0.0 0.0.0.0 10.1.0.7
ip route 0.0.0.0 0.0.0.0 10.1.0.3
Then Saved it to Running Config.
Now that Route shows as Editable, none of the others do.
