SG350-28 Trunk Ports not holding tagged VLANs
elliots
Hi there,
When I load the config attached, if I go into VLAN management afterwards, GE12, LAG 1 and LAG 2 have lost all their tagged VLAN settings. This has happened a couple of times now or when I reboot the switch, the problem arises again. GE12 for example now just has 65UI there and not 60-64T. If I then pull a backup file from the switch now, the config will now say 'switchport trunk port allowed vlan none' under GE12. I have also tested the config once I have uploaded it and it doesn't work.
I am aware VLAN 65 is inactive but we only need one port on this switch, then on the other end there could be a port with 65U to attach a Ubiquiti cloudkey for example so I assume this isn't the problem.
Love any explanation or insight to why this is happening. Is there something obvious I'm missing in the config?
Many thanks,
Elliot
2 Accepted Solutions
Jaderson Pessoa
Helllo @elliots ,
There are inconsistency configuration on your file.
I suggest you allowed just vlans that you need  instead use remove command
interface GigabitEthernet12
switchport mode trunk
switchport trunk native vlan 65 /
switchport trunk allowed vlan remove 1-59,65-4094   << try change switchport trunk allowed vlan 65, but if this post is part of LAG 1 or 2, the same command is necessary on LAG
interface Port-Channel1
description ASR_LAG1
switchport trunk native vlan 99
switchport trunk allowed vlan remove 1-9,11-59,71-4094
interface Port-Channel2
description ASR_LAG2
Jaderson Pessoa
*** Rate All Helpful Responses ***
Deepak Kumar
Edited:
It looking the Native VLAN of Port 12 and Port-channel 2 are also removed.
Check again the configuration.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
6 Replies 6
Jaderson Pessoa
Helllo @elliots ,
Jaderson Pessoa
Hey Jaderson,
Thanks for that, knew it would be something I was missing. I had been editing this from the web interface rather than text file so is there something I could have missed there that would cause this to happen in GUI?
Really appreciate your help!
Elliot
Hello, Elliots,
I think that is a missing configuration, not a bug. By the way, you can upgrade your IOS.
Jaderson Pessoa
Deepak Kumar
Edited:
Deepak Kumar
Deepak Kumar,
Hey Deepak,
Thank you for that, really helpful. One other thing, I just posted to Jaderson as well, I was editing this from inside the web interface so not sure how I ended up removing the VLAN at the same time? Do you have any ideas? Just trying to make sure I don't fall in the same trap again in the future.
All the best,
Elliot
I am not sure what was happened but here is a page which will help you to get all the details about the VLAN.
Login in the Switch--->VLAN Management--->Port VLAN Membership--->Select desire Port-->Join VLAN--->and Change VLAN as required.VLAN in once.png
Deepak kumar
Deepak Kumar,
