BFD neighbor can't be established between CISCO 9300 and Juniper device
we got an issue tha BFD neighbor can't be established between CISCO 9300 and Juniper device, please help to check the following configuration. thanks a ton if you can share any idea.
C9300
interface GigabitEthernet1/0/3
no switchport
ip address 198.19.127.18 255.255.255.252
no ip redirects
bfd interval 500 min_rx 500 multiplier 3
end
When
ip route static bfd GigabitEthernet1/0/3 198.19.127.17
nothing display under"show bfd nei"
When
ip route static bfd GigabitEthernet1/0/3 198.19.127.17 unassociate
show bfd nei
NeighAddr LD/RD RH/RS State Int
198.19.127.17 1/0 Down Down Gi1/0/3
ip route 172.31.0.0 255.255.0.0 198.19.127.17
Juniper configruation
Set routing-options static route 172.6.80.0/29 next-hop 198.19.127.18
Set routing-options static route 172.6.80.0/29 bfd-liveness-detection minimum-interval 500
Set routing-options static route 172.6.80.0/29 bfd-liveness-detection minimum-receive-interval 500
Set routing-options static route 172.6.80.0/29 bfd-liveness-detection multiplier 3
Set interfaces ge-0/0/3 unit 0 family inet address 198.19.127.17/30
Ping has no problem from 198.19.127.18 to 17
#ping 198.19.127.17
Sending 5, 100-byte ICMP Echos to 198.19.127.17, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 5/9/11 ms
marce1000
 - Check the logs on both platforms after the intended setup has been done , look for errors or info's
 M.
balaji.bandi
I am also keen to see  Juniper what device model of Juniper and version of code running that device.
post juniper config and below out form both the devices :
Cisco
#sh bfd neighbors details
Juniper
> show bfd session detail
also worth looking at Juniper community :
https://kb.juniper.net/InfoCenter/index?page=content&id=KB33891&cat=JUNOS_PLATFORM&actp=LIST
BB
as far as I recall, on Juniper devices, by default, BFD is supported on single-hop static routes. Depending on your model, you need to configure extra options in order to support multiple hops. The link below shows how to do that on the EX72/73/74:
https://kb.juniper.net/InfoCenter/index?page=content&id=KB22071
And on MX devices, it is not supported at all:
'On MX Series devices, multihop BFD is not supported on a static route if the static route is configured with more than one next hop. It is recommended that you avoid using multiple next hops when a multihop BFD is required for a static route.'
