SG350XG-2F10 flapping port
madarasz
Hi guys,
I would like to ask you for help with my problem.
Description of environment:
2 switches SG350XG-2F10 in stack.
ProLiant DL380 Gen10 with 2 network cards Adapter 1 - HPE Eth 10/25Gb 2p 640FLR-SFP28 Adptr, Adapter 2 - HP Ethernet 10Gb 2-port 530T Adapter
Adapter1 connected with both ports to unit2 port -XG11 and XG12
Adapter2 connected with port 1 to unit 1 port 7, and port2 to unit 2 port 7
The problem is the port7 of unit 1 is flapping. It does not matter if I connect it to unit1 or unit2 to any free port it is still flapping. We thougth the problem is the adapter but it was changed and problem still persist. If I will connect the cable to other switch which is not in the stack it works correct.
Could anybody help me what should I try or what can be the problem?
Thank you and have a nice day.
Regards Martin
6 Replies 6
marce1000
   - Check port counters on the flapping ports , check error-related counters.
 M.
Hi thank you for fast reply, There is 0 packets with errors.
 - Have devices at the other end such as the Proliant checked for networking errors through the tools that the operating system provides , in Windows you have for instance eventvwr , here is an example : https://kb.iu.edu/d/bfvh
 M.
there is vsphere and I tried it to find cause the problem but without any network error.
sounds like it could be related to spanning tree. Can you try and disable spanning tree on port 7 of stack unit 1 ?
https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/350xseries/2_5_7/Administration/tesla-350-550/cb_350_chapter_11.html#ID-00003889
Hi, Thank you, I tried it but same result of flapping
