SG500 28P Join VLAN popup window blank
nick.sharpley
From the VLAN Management  menu option, Port VLAN Membership, I select a port and click the Join VLAN button.
The popup window to edit VLAN membership is blank and cannot be edited.
Initially, it opens as a tiny window, but I can adjust the size.
There are no configurable elements.  No VLANs to chose.
All other similar popup windows in the swtich config are fine.
I can change VLAN membership, and every thing else, via command line.
I have tried multiple browsers and multiple machines.  Same result.
I also reset the switch to factory, no change.
marce1000
             - Make sure to use the latest firmware on the SG500 28P
 M.
nick.sharpley
That did it ... thanks.
