ws3560 reloading itselfs
sanjar200994
Hello, I met strange problem for me. Few days ago WS-C3560CX-12TC-S started rebooting every day (3-4 times). I changed switch to another new WS-C3560CX-12TC-S but I still have same situation. Temperature is normal, power supply to (all devices connected from 1 socket, but just this switch rebooting). Please help ...
Show log command
3560cx Next reboot level = ipbase and License = No valid license found
Jan 11 01:22:07.956: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
Jan 11 01:22:09.396: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
Jan 11 07:22:14.083: %SYS-6-CLOCKUPDATE: System clock has been updated from 01:22:14 UTC Tue Jan 11 2000 to 07:22:14 KG Tue Jan 11 2000, configured from console by console.
Jan 11 07:22:14.272: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan10, changed state to down
Jan 11 07:22:14.306: %SYS-5-CONFIG_I: Configured from memory by console
Jan 11 07:22:14.653: %SYS-5-RESTART: System restarted --
13 Replies 13
Leo Laohoo
Post the complete output to the following commands:
sh version
dir
sh log on uptime detail
sh version
Cisco IOS Software, C3560CX Software (C3560CX-UNIVERSALK9-M), Version 15.2(4)E8, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Fri 15-Mar-19 12:14 by prod_rel_team
ROM: Bootstrap program is C3560CX boot loader
BOOTLDR: C3560CX Boot Loader (C3560CX-HBOOT-M) Version 15.2(4r)E5, RELEASE SOFTWARE (fc4)
m-sokul-sw1 uptime is 1 hour, 0 minutes
System restarted at 07:21:14 KG Tue Jan 11 2000
System image file is "flash:/c3560cx-universalk9-mz.152-4.E8/c3560cx-universalk9-mz.152-4.E8.bin"
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Default. No valid license found.
Next reload license Level: ipbase
cisco WS-C3560CX-12TC-S (APM86XXX) processor (revision L0) with 524288K bytes of memory.
Processor board ID FOC2327T1YQ
Last reset from power-on
2 Virtual Ethernet interfaces
16 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : D4:AD:BD:D9:41:80
Motherboard assembly number : 73-100863-04
Power supply part number : 341-0208-03
Motherboard serial number : FOC232602N6
Power supply serial number : LIT23202J2E
Model revision number : L0
Motherboard revision number : C0
Model number : WS-C3560CX-12TC-S
System serial number : FOC2327T1YQ
Top Assembly Part Number : 68-100570-01
Top Assembly Revision Number : E0
Version ID : V04
CLEI Code Number : CMM1K10DRB
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
* 1 16 WS-C3560CX-12TC-S 15.2(4)E8 C3560CX-UNIVERSALK9-M
Configuration register is 0xF
dir
Directory of flash:/
2 -rwx 4073 Jan 7 2000 07:55:35 +06:00 config.text
3 -rwx 736 Jan 7 2000 07:53:00 +06:00 vlan.dat
5 -rwx 3835 Jan 7 2000 07:55:35 +06:00 private-config.text
6 drwx 512 Jul 5 2019 13:48:12 +06:00 c3560cx-universalk9-mz.152-4.E8
577 drwx 512 Jul 5 2019 13:48:13 +06:00 dc_profile_dir
579 -rwx 3096 Jan 11 2000 07:22:19 +06:00 multiple-fs
122185728 bytes total (95288320 bytes free)
UPTIME SUMMARY INFORMATION
First customer power on : 07/05/2019 14:06:43
Total uptime : 0 years 0 weeks 4 days 23 hours 30 minutes
Total downtime : 0 years 0 weeks 0 days 15 hours 55 minutes
Number of resets : 10
Number of slot changes : 0
Current reset reason : 0x0
Current reset timestamp : 01/11/2000 07:27:14
Current slot : 1
Current uptime : 0 years 0 weeks 0 days 0 hours 55 minutes
Reset | |
Reason | Count |
No historical data to display
UPTIME CONTINUOUS INFORMATION
Time Stamp | Reset | Uptime
MM/DD/YYYY HH:MM:SS | Reason | years weeks days hours minutes
07/05/2019 14:06:43 0x9 0 0 0 0 0
07/05/2019 15:13:24 0x9 0 0 0 0 5
07/06/2019 06:11:55 0x0 0 0 0 0 5
07/05/2019 14:06:43 0x0 0 0 0 0 0
07/05/2019 14:06:43 0x0 0 0 1 14 0
07/05/2019 14:06:43 0x0 0 0 0 4 0
07/05/2019 14:06:43 0x0 0 0 0 0 10
07/05/2019 14:06:43 0x0 0 0 2 7 0
07/05/2019 14:06:43 0x0 0 0 0 21 0
07/05/2019 14:06:43 0x0 0 0 0 0 15
Take the same switch, the one rebooting constantly, to a different part of the building.  See if it is still "reloading itself".
do you mean that it could be electrical problems?
If 2 different switches have the same problem when connected there it certainly could be some issue with power there. I think the suggestion to try the original switch is a different location is a good idea.
Is it possible to have something connected to the console and displaying console messages? It might be helpful to know if there were any console messages at the time that the switch reloaded.
Rick
Exactly.
Mark Elsen
           - Issue the show version command and have a look at the reload reason ,
 M.
Do you use any EEM or script to reboot the SW?
Check time between reboot if interval is same then there is something in your config it not HW issue.
there are no scripts and something than can reload this switch. In config I just use different vlans on different ports. HW issue could be, but I have 20 other same switches and they work normally
As @Leo Laohoo  mention check power supply inlet. Also check cpu history always.
Richard Pidcock
You could try upgrading the code to a different version I suppose, but looking at the "show version" output provided above shows the following which might lead me to believe it's a power issue as suggested by others.  If you could move it to another power source that would be a good validation step.
Richard W. Pidcock
sanjar200994
thank you everyone, really it was problem with electricity, I didn't know that in this office 2 different electro lines. But it still strange that just 3560 reloaded, other equipment worked (router and others). it seems that 3560 is more sensitive to electricity
Thanks for the update. Glad to know that you have identified the issue as an electrical problem.
Rick
