SG550X-24 Memory OIDs
Shahrouzrad
Hello Guys,
It would be really appriciated if you could helo me ti find OIDs to check memory status of switch SG550X-24.
I have tried all of Catalyst OIDs but non of them worked.
Kind Regards,
8 Replies 8
balaji.bandi
These are small business switches, may be limited available (what you looking to get like cat switches)
try snmpwalk with OID 1.3.6.1.4.1.9.6.1.82.24.2 ( what ever you get output that is limited)
also get MIB file from download :
https://software.cisco.com/download/home/286305669/type/283415684/release/2.5.7.85
BB
Hello Balaji,
Thanks for ur comment but unfortunately it dose not work :(.
Kind Regards,
as i said it has limited - what you get outcome when you snmpwalk  against device ?
BB
This is the outcome of Snmpwalk:
snmpwalk -v2c -c xxxxx xx.xx.xx.xx 1.3.6.1.4.1.9.6.1.82.24.2
iso.3.6.1.4.1.9.6.1.82.24.2 = No Such Object available on this agent at this OID
how about this :
BB
There is no problem by SNMP:
snmpwalk -v2c -c xxxxxx xx.xx.xx.xx1.3.6.1.4.1.9.6.1
iso.3.6.1.4.1.9.6.1.101.1.1.0 = INTEGER: 65535
iso.3.6.1.4.1.9.6.1.101.1.2.0 = INTEGER: 26
iso.3.6.1.4.1.9.6.1.101.1.4.0 = Hex-STRING: E0
iso.3.6.1.4.1.9.6.1.101.1.5.0 = INTEGER: 1
iso.3.6.1.4.1.9.6.1.101.1.6.0 = INTEGER: 1
iso.3.6.1.4.1.9.6.1.101.1.7.0 = INTEGER: 3
iso.3.6.1.4.1.9.6.1.101.1.8.0 = INTEGER: 4
iso.3.6.1.4.1.9.6.1.101.1.9.0 = INTEGER: 4
iso.3.6.1.4.1.9.6.1.101.1.10.0 = Timeticks: (4294967295) 497 days, 2:27:52.95
iso.3.6.1.4.1.9.6.1.101.1.12.0 = OID: iso.3.6.1.4.1.9.6.1.101
iso.3.6.1.4.1.9.6.1.101.1.13.0 = INTEGER: 1
iso.3.6.1.4.1.9.6.1.101.1.14.0 = ""
iso.3.6.1.4.1.9.6.1.101.1.15.0 = ""
iso.3.6.1.4.1.9.6.1.101.1.16.0 = ""
iso.3.6.1.4.1.9.6.1.101.1.17.0 = ""
iso.3.6.1.4.1.9.6.1.101.1.18.0 = INTEGER: 2
iso.3.6.1.4.1.9.6.1.101.1.19.1.3.3.1 = STRING: "SG-550X-24"
iso.3.6.1.4.1.9.6.1.101.1.19.1.4.3.1 = INTEGER: 1
iso.3.6.1.4.1.9.6.1.101.1.20.0 = INTEGER: 1
iso.3.6.1.4.1.9.6.1.101.2.4.0 = STRING: "2.5.5.47"
Just suggested (not that SNMP not working), so you get all OID information.
if you do not see them using standard SNMP, then you wont be able to get that information.
download MIB file from site and using that MIB and test SNMP walk.
BB
I did but there was no success
