Shaping issues
Darren Hunter
Community Member
I’m having some difficulty getting traffic shaping to work. I’m trying to setup a basic traffic shaping policy to limit the download speed from the internet, I am using a broadband speed test to check if the policy is working. I am able to get this to work using policing, I can clearly see that the broadband download speed if affected by the policy however it seems that my traffic shaping policy has no effect.
I am applying the policy to the vlan interface outbound.
The policies are below
Policy Map speedlimiter (shaping)
    Class SLOW_PC
    Class class-default
      Average Rate Traffic Shaping
      cir 1%
Policy Map POLICE
    Class SLOW_PC
     police cir 1048500 bc 32765
       conform-action transmit
       exceed-action drop
slow PC is a class-map which matches a single IP address
any help is appreciated, thanks
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Some Cisco switches to not support CBWFQ shaping (although you might be able to configure it).
What device are you trying this on?
Cisco 887va router, it seems odd to allow you to configure this? might this be the same with NBAR? as I can configure the service but our management software reports that it is not supported on the router?
Disclaimer
Posting
I haven't worked on the particular model, but other 800 series appear to support almost all applicable IOS features, for their IOS version, for the "WAN" port.
I.e. it might work correctly there, but not on the SVI.
Hi thanks for the response,
I've attached this policy to the dialer interface and atm interface but it still has no effect?
