Should you not use Vlan 1
nmooremvsc
I've read in some places that it is not advised to use Vlan 1 for security reasons. Is this a real good idea or is it more of pain to implement? If it is something that should be setup and used, what are good tips for making the transition and what all things need to be moved from vlan 1.
Thanks for your help!
7 Replies 7
Edison Ortiz
Please see:
http://www.cisco.com/warp/public/cc/pd/si/casi/ca6000/prodlit/vlnwp_wp.htm#wp39009
on the reasons why is not recommended to use Vlan 1 to carry data traffic.
__
Edison.
Those are the exact reasons I've been thinking about this. However on 2960'2 and 3560's how do you change the management vlan to something else? Also isn't STP and CDP info always transmitted over vlan 1. If it's pruned will the not work correctly?
Let's use Vlan 10 for instance:
interface vlan 1
no ip address x.x.x.x y.y.y.y
shutdown
interface vlan 10
no shutdown
Those are control traffic, not data traffic. Be concerned only about data traffic.
HTH,
__
Edison.
ok that's easy enough. But if you prune vlan 1 from trunks, won't it interrupt the control traffic as well?
"CDP, VTP, and PAgP updates are always forwarded on trunks with a VLAN 1 tag. This is the case even if VLAN 1 is cleared from the trunks and is not the native VLAN. If VLAN 1 is cleared for user data, these is no impact on control plane traffic that is still sent using VLAN 1."
http://www.cisco.com/en/US/products/hw/switches/ps700/products_white_paper09186a00801b49a4.shtml#pre6
__
Edison.
Please rate helpful posts
Vlan 1 is not eligible to be pruned.
