10-19-2014 02:46 PM - edited 03-07-2019 09:10 PM
On Ethernet links, with an 802.1q trunk, the long string of characters (below), indicate dest MAC, src MAC, 802.1q tag and the Ethertype.
sh adjacency fa1/0.200 det
Protocol Interface Address
IPV6 FastEthernet1/0.200 2001:200::4(5)
1 packets, 114 bytes
C4041FE80000C4001FE80010810000C8
86DD
IPv6 ND never
Epoch: 0
With a space between each section, these are the separate parts:
src MAC dst MAC 802.1q EtherType (IPv6)
C4041FE80000 C4001FE80010 810000C8 86DD
However - what's the significance of the leading 81 in the 802.1q portion?
Chris
Solved! Go to Solution.
10-19-2014 11:27 PM
It should be tag protoclol id (TPID) and is used to distinguish the frame from untagged frames.
If you look at 802.1q header, you find a 16-bit field (TPID) set to a value of 0x8100 in order to identify the frame as an IEEE 802.1Q-tagged frame.
10-19-2014 11:27 PM
10-20-2014 01:12 AM
Many Thanks. :-)
