show cdp neighbors command shows two devices connected through the same local port
Jinoymk101
show cdp neighbors command shows two devices connected through the same local port?
I have a Cisco 3560 that when I issue the "show cdp neighbors" command I get the following results:
Switch1#show cdp neighbors
Device ID            Local Intrfce         Holdtme   Capability        Platform   Port ID
Switch2             Gig 0/3                   169               S I             WS-C3560-4Gig 0/4
Switch3             Gig 0/3                   96                 S I             WS-C3560-4Gig 0/2
the question is why is this showing that Gig0/3 is being used twice to  connect to two different devices.  I have verified there is no hub  connected to this port and in fact Switch3 is not connected to Switch1  at all yet it still shows up in the CDP table.
I have cleared the CDP table on every device at this location and still get the same results.  Any ideas or thoughts?
5 Replies 5
Reza Sharifi
Try disconnecting the cable and reconnecting it back.  That might clear CDP.  I have seen it where the CDP doesn't show the neighbor at all and by disconnecting and reconnecting the cable, it works fine.
nickbonifacio
Hi Jinoy,
Is there a patch panel between these switches?  Can you get them connected together without anything in between using a brand new cross over cable?  I would want to rule out layer 1 / cabling.
Thanks!
Nick
Nick Bonifacio CCIE #38473
root_taker
If you have any non CDP aware gear in the mix CDP frames are forwarded to all ports like any other multicast.  I ran into this will Dell switches in between two Ciscos already...
Second Adams remark via some Extreme gear also.
rwhiz56
Update Cisco patches and check IOS versions compatibility on all switches.
