show command for ASR 1004
johnlloyd_13
Level 9
Level 9
hi all,
is there a command available to run diagnostics in ASR port/SPA? the one below is from a juniper remote device.
i was only able to find 'test interface' but haven't run this yet (currently in production). thanks in advance!
#test interface g ?
  <0-0>     GigabitEthernet interface number
  <0-1000>  GMPLS interface number
  <0-1>     GigabitEthernet interface number
> show interfaces diagnostics optics ge-1/1/2
Physical interface: ge-1/1/2
    Laser bias current                        :  16.576 mA
    Laser output power                        :  1.6770 mW / 2.25 dBm
    Module temperature                        :  44 degrees C / 111 degrees F
    Module voltage                            :  3.1960 V
    Receiver signal average optical power     :  0.8565 mW / -0.67 dBm
    Laser bias current high alarm             :  Off
    Laser bias current low alarm              :  Off
    Laser bias current high warning           :  Off
    Laser bias current low warning            :  Off
    Laser output power high alarm             :  Off
    Laser output power low alarm              :  Off
    Laser output power high warning           :  Off
    Laser output power low warning            :  Off
    Module temperature high alarm             :  Off
    Module temperature low alarm              :  Off
    Module temperature high warning           :  Off
    Module temperature low warning            :  Off
    Module voltage high alarm                 :  Off
    Module voltage low alarm                  :  Off
    Module voltage high warning               :  Off
    Module voltage low warning                :  Off
    Laser rx power high alarm                 :  On
    Laser rx power low alarm                  :  Off
    Laser rx power high warning               :  On
    Laser rx power low warning                :  Off
    Laser bias current high alarm threshold   :  100.000 mA
    Laser bias current low alarm threshold    :  6.000 mA
    Laser bias current high warning threshold :  95.000 mA
    Laser bias current low warning threshold  :  6.498 mA
    Laser output power high alarm threshold   :  5.0120 mW / 7.00 dBm
    Laser output power low alarm threshold    :  0.6300 mW / -2.01 dBm
    Laser output power high warning threshold :  3.9810 mW / 6.00 dBm
    Laser output power low warning threshold  :  0.7940 mW / -1.00 dBm
    Module temperature high alarm threshold   :  85 degrees C / 185 degrees F
    Module temperature low alarm threshold    :  -15 degrees C / 5 degrees F
    Module temperature high warning threshold :  80 degrees C / 176 degrees F
    Module temperature low warning threshold  :  -10 degrees C / 14 degrees F
    Module voltage high alarm threshold       :  3.600 V
    Module voltage low alarm threshold        :  3.000 V
    Module voltage high warning threshold     :  3.499 V
    Module voltage low warning threshold      :  3.099 V
    Laser rx power high alarm threshold       :  0.7943 mW / -1.00 dBm
    Laser rx power low alarm threshold        :  0.0025 mW / -26.02 dBm
    Laser rx power high warning threshold     :  0.6309 mW / -2.00 dBm
    Laser rx power low warning threshold      :  0.0031 mW / -25.09 dBm
Ivan Shirshin
Hi John,
There is a command like "show hw-module subslot ... transceiver ... idprom detail" to see port parameters and "show hw-module subslot ... transceiver ... status" to see current status:
Router# show hw-module subslot 4/0 transceiver 2 status
The Transceiver in slot 4 subslot 0 port 2 is enabled.
  Module temperature                = +41.617 C
  Transceiver Tx supply voltage     = 3292.0 uVolts
  Transceiver Tx bias current       = 4840 uAmps
  Transceiver Tx power              = 349.2 uWatts
  Transceiver Rx optical power      = 0.5 uWatts
Router# show hw-module subslot 4/0 transceiver 5 idprom detail
IDPROM for transceiver GigabitEthernet4/0/6:
  Description                               = SFP optics (type 3)
  Transceiver Type:                         = GE SX (19)
  Product Indentifier (PID)                 = FTRJ8519P1BNL-C3
  Vendor Revision                           = A1
  Serial Number (SN)                        = FNS0821K2J5
  Vendor Name                               = CISCO-FINISAR
  Vendor OUI (IEEE company ID)              = 00.90.65 (36965)
  CLEI code                                 = CNUIAAMAAA
  Cisco part number                         = 10-1954-01
  Device State                              = Enabled.
  Date code (yy/mm/dd)                      = 04/05/19
  Connector type                            = LC.
  Encoding                                  = 8B10B
                                              NRZ
  Nominal bitrate                           = 2xFC (2100 Mbits/s)
  Minimum bit rate as % of nominal bit rate = not specified
  Maximum bit rate as % of nominal bit rate = not specified
  Link reach for 9u fiber (km)              = SX(550/270m) (0)
                                              1xFC-MM(500/300m) (0)
                                              2xFC-MM(300/150m) (0)
                                              ESCON-MM(2km) (0)
  Link reach for 9u fiber (m)               = SX(550/270m) (0)
                                              ESCON-MM(2km) (0)
  Link reach for 50u fiber (m)              = 2xFC-MM(300/150m) (30)
  Link reach for 62.5u fiber (m)            = 2xFC-MM(300/150m) (15)
  Nominal laser wavelength                  = 850 nm.
  DWDM wavelength fraction                  = 850.0  nm.
  Supported options                         = Tx disable
                                              Tx fault signal
                                              Loss of signal (standard implementation)
  Supported enhanced options                = Alarms for monitored parameters
  Diagnostic monitoring                     = Digital diagnostics supported
                                              Diagnostics are externally calibrated
                                              Rx power measured is "Averagepower"
  Transceiver temperature operating range   = -5 C to 85 C (extended)
  Minimum operating temperature             = -20 C
  Maximum operating temperature             = 90 C
  High temperature alarm threshold          = +109.000 C
  High temperature warning threshold        = +103.000 C
  Low temperature warning threshold         =  -13.000 C
  Low temperature  alarm threshold          =  -29.000 C
  High voltage alarm threshold              = 3.9000 Volts
  High voltage warning threshold            = 3.7000 Volts
  Low voltage warning threshold             = 2.9000 Volts
  Low voltage alarm threshold               = 2.7000 Volts
  High laser bias current alarm threshold   = 15.000 mAmps
  High laser bias current warning threshold = 12.000 mAmps
  Low laser bias current warning threshold  = 2.000 mAmps
  Low laser bias current alarm threshold    = 1.000 mAmps
  High transmit power alarm threshold       = 0.7424 mWatts
  High transmit power warning threshold     = 0.7424 mWatts
  Low transmit power warning threshold      = 0.959 mWatts
  Low transmit power alarm threshold        = 0.619 mWatts
  High receive power alarm threshold        = 5.9324 mWatts
  High receive power warning threshold      = 3.7416 mWatts
  Low receive power warning threshold       = 0.751 mWatts
  Low receive power alarm threshold         = 0.478 mWatts
  External Calibration constant: Rx power4  = 0.000
  External Calibration constant: Rx power3  = 0.000
  External Calibration constant: Rx power2  = 0.000
  External Calibration constant: Rx power1  = 0.212
  External Calibration constant: Rx power0  = -1.4294966868
  External Calibration: bias current slope  = 1.000
  External Calibration: bias current offset = 0
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
6 Replies 6
Ivan Shirshin
Hi John,
  Encoding                                  = 8B10B
                                              NRZ
                                              ESCON-MM(2km) (0)
                                              ESCON-MM(2km) (0)
                                              Tx fault signal
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
ivan,
you're awesome! thanks!
i tried googling for CLI commands for ASR but only gave me specs. would highly appreciate if you could give me a link?
>sh hw-module subslot 0/0 transceiver 4 status
The Transceiver in slot 0 subslot 0 port 4 is enabled.
  Module temperature                        = +32.437 C
  Transceiver Tx supply voltage             = 3271.0 mVolts
  Transceiver Tx bias current               = 28796 uAmps
  Transceiver Tx power                      =  2.9 dBm
  Transceiver Rx optical power              = -26.6 dBm
>sh hw-module subslot 0/0 transceiver 4 idprom detail
IDPROM for transceiver GigabitEthernet0/0/4:
  Transceiver Type:                         = GE ZX (23)
thanks a lot!
Welcome and thanks for ratings!
Kind Regards,
Ivan
CSCO11868810
Hello guys,
there is a way to enable log on ASR 1000 for transceiver problem about TX/RX power?
i can see the values of TX RX by the command : sh hw-module subslot 0/0 transceiver xxx....., but if i have a problem the device doesn't reply any logs....
thks,
Ale
