Show Interface Input Errors
monkp
Community Member
When doing a show inteface - What do Input Errors indicate?
ankurbhasin
Level 11
Level 11
HI Monkp,
The input errors includes runts, giants, no buffer, CRC, frame, overrun, and ignored counts. Other input-related errors can also cause the input error count to be increased, and some datagrams may have more than one error.
Have a look at this link
http://www.cisco.com/univercd/cc/td/doc/cisintwk/itg_v1/tr1904.htm#wp1020942
Ankur
Ankur,
Here is the output from show int ...The only thing incrementing is the input errors but what type of problem does that indicate?
JSC-1#sh int gigabitEthernet 11/1
GigabitEthernet11/1 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0012.0092.a260 (bia 0012.0092.a260
Description: GL1
MTU 1500 bytes, BW 100000 Kbit, DLY 10 usec,
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is off
Clock mode is auto
Last input never, output 00:00:35, output hang never
Last clearing of "show interface" counters 1d03h
Input queue: 0/2000/41/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 645000 bits/sec, 66 packets/sec
5 minute output rate 305000 bits/sec, 63 packets/sec
1152632 packets input, 910547914 bytes, 0 no buffer
Received 2068 broadcasts (1650 multicast)
41 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
1917609 packets output, 964325920 bytes, 0 underruns
hi monkp,
Congestion in network on interface can result in inpur errors or any bad packets processed by the interface may result in input errors.
Ankur
You'll notice that the "input errors" count is exactly the same as the "drops" shown on the Input queue line. This means that the packet that caused the input error was dropped by the router as the input queue for the interface was already full.
This problem can be caused by the fact the TX ring on the egress interface is full, typically due to the ingress interface being of a much higher speed than the egress interface.
Also take a look at "Troubleshooting Input Queue Drops" at http://www.cisco.com/en/US/partner/products/hw/routers/ps133/products_tech_note09186a0080094791.shtml#topic2.
Steve
