Show interface Switchport on Nexus 3000 series
Good day all,
I've been doing some testing and investigations and came upon this output that I cant quite explain. The output below shows the "Show interface switchport" output for a particular interface on my Nexus 3000 series switch.
According to the output below, "Mac Learning" is Disabled. However when I look in the mac address table i'm seeing dynamically learnt mac addresses on this port. Could someone shed some light as to what the "Mac Learning" parameter means and why if it's disabled I would still be learning Mac addresses dynamically on the same port.
Switchport: Enabled
Switchport Monitor: Not enabled
Switchport Isolated : Not enabled
Switchport Block Multicast: Not enabled
Switchport Block Unicast: Not enabled
Mac learning: Disabled
Operational Mode: access
Access Mode VLAN: XXX
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Allowed: 1-4094
Administrative private-vlan primary host-association: none
Administrative private-vlan secondary host-association: none
Administrative private-vlan primary mapping: none
Administrative private-vlan secondary mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk private VLANs: none
Operational private-vlan: none
0 Replies 0
