show platform port-asic stat drop on non-master switch
I have a 2 switch, 3750 stack. Switch 1 is the master. I have QOS enabled. When I enter the following command:
show platform port-asic stats drop fastEthernet 1/0/1
it works, but if I enter the command
show platform port-asic stats drop fastEthernet 2/0/1
I receive the following error:
%Command Rejected: interface 'FastEthernet2/0/1' is not local port
How do I look at port drops for a non-maser switch in a stack?
You need to prefix the command with 'remote command x' where 'x' is the stack member. For example:
remote command 2 show platform port-asic stats drop fastethernet 2/0/1
In the latest 12.2(50)SE IOS the drop and enqueue stats from these commands are included in the 'show mls qos interface statistics' command.
Andy
Andy
Brilliant! Thanks!
