03-09-2023 11:26 PM
For the output results of the following commands
Could you please tell me what it indicates?
Also, I have port channels in a stacked configuration, and the Group Mask values for active and standby are different, can you tell me the possible cause?
show platform software fed switch active etherchannel 1 group-mask
show platform software fed switch standby etherchannel 1 group-mask
03-09-2023 11:45 PM
- Perhaps you could show the output results too (?)
M.
03-10-2023 03:11 AM
The following is the output result.
#show platform software fed switch active etherchannel 1 group-mask
Group Mask Info
Aggport IIF Id: 000000000000007b
Active Port: : 2
Member Ports
If Name If Id local Group Mask
GigabitEthernet2/0/1 0000000000000099 true 3333333333333333
GigabitEthernet1/0/1 000000000000006e false bbbbbbbbbbbbbbbb
#show platform software fed switch standby etherchannel 1 group-mask
Group Mask Info
Active Port: : 3
Member Ports
GigabitEthernet1/0/1 000000000000006e true 4ec4ec4ec4ec4ec4
GigabitEthernet2/0/1 0000000000000099 false c4ec4ec4ec4ec4ec
GigabitEthernet1/0/2 000000000000006d true ec4ec4ec4ec4ec4e
03-10-2023 03:16 AM
group-mask,
each PO have group-mask and each port have ID that true (within group-mask) meaning this port is port member of this PO or false(out of group-mask) meaning this port is NOT member port of this PO.
03-10-2023 06:01 AM
Thank you very much.
I understood that the group mask of the port is different between Active and Standby because of the different POs they belong to.
03-10-2023 06:26 AM
it internal SW ID, it not configurable, and Yes it different from SW to other.
