#show policy-map control-plane
D@1984
I'm trying to see if the packets for a class-map I set is within the rate that I set in my policy-map, how many packets dropped, etc but when I do show policy-map control-plane, there is no output:
Load for five secs: 1%/0%; one minute: 6%; five minutes: 7%
Time source is NTP,....
I only set class-map for routing protocols and icmp , and I would like to see what are other traffic that matching the class-default and going through the control plane.
Reza Sharifi
Can you tell us what type of device you are using? Also, can you post the "policy-map" configuration?
does 'show policy-map control-plane all' reveal anything ?
no, nothing.
