Show Redundancy Boot System Output Question
emaperez99
I was entering the command show redundancy on a 6K switch to verify the boot variable on the switch and when reading the output it shows something like this:
BOOT= bootdisk:filename.bin, 12;
I was wondering, what does that "12" means?
Thank you!
Reza Sharifi
When you issue "sh bootvar" does it show the same thing?
Yes, it show the same thing
BOOT variable = bootdisk:filename.bin,12;
The image is booting fine and everything is working as expected, I was just wondering what does that 12 mean.
Thanks!
