Show Supervisor Backplane Packets Per Second
ericn8484_2
Level 3
Level 3
I am looking for the show command that will show the total packets per second going through the switch. I thought I had the command at one point but am having troubles finding it. Every time I look for back plane utilization, all I can find is the CPU.
Collin Clark
I don't think I've ever seen pps, but here might be a couple of helpful commands;
6503-1#show platform hardware capacity ?
acl Show QoS/Security ACL capacity
cpu Show CPU resources capacity
eobc Show EOBC resources capacity
fabric Show Switch Fabric resources capacity
flash Show Flash/NVRAM resources capacity
forwarding Show forwarding engine capacity
ibc show IBC resources
interface Show Interface resources capacity
monitor Show SPAN resources capacity
multicast Show L3 and LTL Multicast resources
netflow Show Netflow capacity
pfc Show PFC resources capacity
power Show Power resources capacity
qos Show QoS resources capacity
rate-limit Show CPU Rate Limiters capacity
system Show System resources capacity
vlan Show VLAN resources capacity
| Output modifiers
6503-1#show catalyst6000 ?
all show all Catalyst 6000 information
chassis-mac-addresses chassis MAC address range
switching-clock switching-clock failure recovery mode
traffic-meter current and peak traffic meter reading
| Output modifiers
6503-1#show fabric ?
active crossbar fabric linecard active and backup info
channel-counters fabric channel counters
clear-block clear-block congestion control for fabric channels
drop drop counters for different queues in fabric
errors fabric port errors
status status of crossbar fabric
switching-mode crossbar fabric and system switching modes
utilization fabric port utilization percentage
| Output modifiers
