shutdown OSPF virtual-link !
mohammed hashim
hi,
is there a way to shutdown OSPF virtual-link without removing area virtual-link command ?
Ganesh Hariharan
hi,
Hi Mohammed,
In order shutdown a virtual link , you need to perform no area virtual-link only.
OSPF graceful shutdown is another feature which can be used to shutdown ospf on specific interface or on device itself.
To initiate a graceful shutdown of an interface , ip ospf shutdown is the command and shutdown command under router configuration mode to completely shutdown ospf in router.
Hope it Helpss.
-GI
Rate if it Helpss
Hello
You should be able to apply authentication on one end of the VL , that should drop the adjaency
area x virtual-link x.x.x.x  authentication
or if you already hae authentication enabled, disable it......
area x virtual-link x.x.x.x  authentication null
res
Paul
Kind Regards
Paul
