Should an entire Port-Channel be blocking?
I got a Topology.
Everything was configured correctly, I've veried that all Port-Channels are working on all Switches...all hosts can talk to each other in their respective VLANS.
I got Trunks on every link between all the Switches.
My show etherchannel summary indicates the Port Channel is GOOD though:
Sw1#show etherchannel summary
Flags: D - down P - in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 2
Number of aggregators: 2
Group Port-channel Protocol Ports
1 Po1(SU) LACP Gig0/1(P) Gig0/2(P)
However, you'll notice that two Gigabit ports (Port-Channel 1 on that Switch) are ORANGE...meaning BLOCKED...and this was verified when I ran show spanning-tree on that Switch
Is this supposed to happen?
jhager001
Yes, even if one of those links were green in your LACP portchannel you would still be performing a loop, therefor it has blocked due to the fact you have more links (aggregated bandwidth) between the other switches so it's allowing more transmission between.
6 Replies 6
Rolf Fischer
Level 9
Level 9
spanning-tree treats a port channel like a single link (just with lower costs than the physical member-ports).
So from a spanning-tree perspective, the three switches are interconnected to each other and STP has to break the loop at some point. The sequence to determine the roles and states follows the same rules as it does when switches are interconnected with single (physical) links.
Rolf
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
As Rolf says.  A port-channel is seen as a single link.  If the port-channel is L2, and its existence would create a L2 loop, then STP might block it.  What link will actually get block follows ordinary STP rules.
Ganesh Hariharan
Considering the topology the blocked ports are two link ether channel compare to other 4 port ether channel.
Port cost for the ether channel is updated immediately in order to reflect the new available bandwidth.
Check out the below table for more detail..
Hope it Helps..
-GI
Rate if it Helpss
glen.grant
  With that design it is definetly correct.  You have a built in loop so spanning tree chose to block the link (port-channel)  with the lowest bandwidth .  It did it's job and is working as designed.  If you do a show spanning-tree  blockedports  if will show that entire channel as blocked.
jhager001
hey thanks everybody, that was helpful
