04-10-2008 11:24 AM - edited 03-05-2019 10:20 PM
I have a layer 3 network where we must have Vlan 1 running for a vendors equipment. Outside of the layer 3 routing switch, can I shutdown the Vlan 1 interface on other switches and still have ports on that switch using Vlan1 in access mode?
Thanks!
Solved! Go to Solution.
04-10-2008 11:33 AM
Yes absolutely as the vlan 1 interface on your other switches, L2 i'm assuming, are purely used for management of the switches and will not affect the forwarding of packets from hosts/servers connected into ports in vlan 1.
How are you going to remotely manage the other switches ?
Jon
04-10-2008 11:33 AM
Jon
04-10-2008 11:35 AM
Jon
Thanks, I have a network management vlan setup that will be used for remote managment.
-Matthew
04-10-2008 11:37 AM
Matthew
Good because i had a vision of you shutting all the vlan 1 interfaces down and then not being able to telnet to the switches 🙂
Jon
04-10-2008 11:41 AM
Yeah that would be bad! I've worked with layer 3 before a number of times at previous employers but this is the first time I have designed and setup a network from scratch. I'd rather not have used Vlan1 at all but i have a PITA vendor who uses cisco gear and insists their switch must be on vlan 1 so here we are!
