Shutting down a module in Catalyst 9606R chassis with dual sup-1 cards
clive.hodgetts
Hi All,
I'm in the process of testing a newly provisioned pair of Catalyst 9607R. I wanted to shutdown a specific module in either of the switches. I followed the Cisco guide 'powering down a line card' for my version of software (17.9) which states the command to use in config mode:
hw-module slot 1/0 shutdown unpowered
As I am running these switches as a pair I added the 'switch x' syntax as follows:
hw-module switch 2 subslot 2/0 shutdown unpowered
With that command I receive the following error:
% This command is not supported for card in 2/0.
I have attempted this for all modules in switch 1 & switch 2 but I receive the same error.
The modules installed are:
C9600-LC-24C
C9600-LC-48YL
C9600-SUP-1
C9600-SUP-1
C9600-LC-48YL
C9600-LC-48YL
What is the reason for this command being invalid and is there any other way of shutting/powering down a module within the 9607R?
Clive
Yes you are right, this command works for Line card not for sup card, I have checked in 17.06.05.
in Supervisor  card the only option it gives " logging". While in Line card it gives "logging" and "shutdown " option.
Shambhu Kumar
8 Replies 8
Reza Sharifi
Are these switches configured as Stackwise Virtual? What is the exact command you are using, as it is supposed be be supported staring Cisco IOS XE Gibraltar 16.11.1
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9600/software/release/17-3/configuration_guide/sys_mgmt/b_173_sys_mgmt_9600_cg/environmental_monitoring_and_power_management.html
For testing, you can also take out the blade from the chassis, which will take it our of production completley.
Hi Reza,
The configuration notes do confirm the command is valid. The switches are stacked (stackwise-virtual) hence the 'switch' addition in the syntax:
switch#conf t
Enter configuration commands, one per line. End with CNTL/Z.
switch(config)#hw-module switch 2 subslot 2/0 shutdown unpowered
switch(config)#
Just to reiterate, I have attempted to use this command with all the modules and each one receives the same error message.
This screenshot taken from 9606R with stackwise-virtual version 17.12.04.
Try with shutdown
switch(config)#hw-module switch 2 subslot 2/0 shutdown shutdown
or
switch(config)#hw-module switch 2 slot 2/0 shutdown unpowered
I have attempted those commands which are all invalid. The third command is valid but I receive the error that it is not supported....
I have now run the command you suggested correctly and it has worked as I wished:
Note: this command only works on line cards and NOT sup cards, whether redundant or otherwise.
Shambhu Kumar
Leo Laohoo
What is the exact firmware version?
Hi Leo,
Version:
switch#sh ver
Cisco IOS XE Software, Version 17.09.05
Cisco IOS Software [Cupertino], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 17.9.5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2024 by Cisco Systems, Inc.
Compiled Tue 30-Jan-24 15:48 by mcpre
