Sim Card for PCEX-3G-HSPA
Patrick McHenry
Level 4
Level 4
Is the sim card included inside the PCEX-3G-HSPA or is this an additional piece added seperately?
Thanks, Pat.
I posted this before on another category and it wasn't getting any hits so I thought it might do better here.
Sorry for the repeat.
Tagir Temirgaliyev
sim card is not included
sim card you can get from cellular provider whitch provides corporate data access service.
also provider must give you APN name, pap or chap authentication and user/password
dont forget to rate post
Thanks for the response. Where does the sim card go? I saw a doc that showed that the sim card went into a HWIC module off the diag port but, my 881 doesn't have a seperate module, just a diag port.. I also opened up the router and could not see anywhere to put it. Does it snap into the PCEX-3G-HSPA module?
Thanks, PAt.
yes
sim card must be inserted into the PCEX-3G-HSPA module
