Simple DSCP marking
davidmesquita
Hello
I am trying to set up a simple configuration on a Cisco 4928-10G switch running
cat4500-entservicesk9-mz.122-37.SG.bin
All I want to do is to mark all trafic on vlan 3 let's say for this example with dscp af31.
All outgoing trafic to be marked with DSCP AF31.
In pratice If I have 2 laptops connected to access ports on vlan 3.
When one laptop pings the other I want to see on the receiving end when I run wireshark the traffic to come marked with DSCP AF31.
Any suggestions of sample configurations guys ?
Thank you in advance.
Hi ,
You must set on every port the default DSCP value. For AFxy the dscp value is 8*x + 2*y.
qos
qos dbl
int gi4/1
qos dscp 26
show qos int gi4/1
Dan
Hi ,
qos
qos dbl
int gi4/1
qos dscp 26
show qos int gi4/1
Dan
