02-07-2012 10:24 AM - edited 03-07-2019 04:47 AM
I have a 6509 at a remote office that is being replaced by a pair of 3750's (6509 was overkill). I have a port on the 6509 that is configured like this -
interface GigabitEthernet1/1
description Riverbed:Inpath 0_0 then to Firewall
ip address 10.1.1.1 255.255.255.0
I have never seen a port on a 6509 configured like this. Havent been able to find out why it was set up this way. The rest of the office is on another subnet i.e. 10.1.2.0 255.255.255.0. I can only guess why the port was setup this way. Unfortunately, I am working with a "managed" network, so the carrier handles the router at the office and I cant make any changes myself and have to go though a series of requests/explanations/etc with them to get any changes mande. It will be easiest to make the 3750 work in a similar manner.
I have tried to configure the 3750 to do the replacement port Gi1/0/1 exactly the same way and have been able to get it to take the ip address command. Only thing I can figure out is to create another vlan on the switch, put the ip address for gi1/1 in that vlan interface and then put the port that will replace Gi1/1 on the 3750 into that new vlan.
I am not running any routing protocols on the 6509 and only see a static route pointing to a different address on the 10.1.1.0 subnet from the 6509 which I believe is the onsite firewall. If there is another way around this, I would appreciate any suggestions. A junior engineer will be going out instead of me, so I would like to have this as plug and play as possible.
Ron
Solved! Go to Solution.
02-07-2012 10:34 AM
On 6500 series all the ports are by default Layer 3 ports.
On 3750 series all the ports are by default Layer 2 ports.
So the solution for 3750 is :
interface fa1/0/1
no switchport
ip add 10.1.1.1 255.255.255.0
"no switchport" , transforms the Layer 2 port into a Layer 3 port.
Dan
02-07-2012 10:34 AM
interface fa1/0/1
no switchport
Dan
02-07-2012 10:44 AM
Dan:
Many thanks for that. Wouldnt have thought about that. Also appreciate the clarification on the differences between the two platforms. I have my CCNP Security but this reinforces why I need to get my CCNP R/S.
Ron
