Simple migration
CSCO11544512
Community Member
I'm a network administrator and I need help to migrate this architecture.
For the moment, there are no VLANs (I suppose).
I don't have a lot of experience with migration.
- Do you think the topology is good ?
- I have to add VLAN (including a DMZ), how do I route between these vlan ? I'm not sure they want to change the router.
Any advice would be welcome.
Martin Carr
Level 8
Level 8
To route between VLAN'S you will have to use 'Router on a stick', as those are L2 switches.
Martin
Thanks.
So I have to use this function on the Fortinet.
An other question : what is the correct way to link switches ? On the last ports ?
Martin Carr
Level 8
Level 8
You need to configure the two interconnected switch interfaces as trunk links, this can be any port, generally the last port is used though, at the moment you just have simple uplinks.
Martin
