QoS configuration on switch 2960
Sylvain Brault
Hi everyone,
I have a 10 Mb link between two 2960 switch with two VLAN and want to configure the QoS to prioritise one VLAN (network 192.168.1.x)
Here is the configuration on the switchs :
Switch 1
class-map match-any classIPC
match access-group 10
policy-map IPS_QOS_policy
class classIPC
  set dscp ef
interface FastEthernet0/23
switchport mode trunk
service-policy input IPS_QOS_policy
access-list 10 permit 192.168.1.0 0.0.0.255
Switch 2
class classIPC
  set dscp ef
interface GigabitEthernet0/19
When I overload the bandwidth ob the VLAN 1 (network 192.168.0.x), I have a timed out from the ping between two device on the VLAN 2 (network 192.168.1.x). It seems the QoS does not work correctly.
Do you have any idea ?
Thanks for your help
0 Replies 0
