Simple OSPF configuration, but not work as I imagined
berniechen
I try to set up a very simple OSPF configuration.  Cause I do not have Cisco router, it is tested by qugga in VM.
RTA(192.168.0.1) <------->(192.168.0.2) RTB (192.168.2.2)<--------> (192.168.2.3)RTC
All of interfaces belong back-bone area.
When I ping 192.168,2,2 from RTA, it is OK. Then I ping 192.168.2.3, it fails. I paste running-config below. It is quite simple. Can anyone tell me what is wrong with it. It is a quagga's issue, configuration issue or it just work as OSPF designed?
BTW, I try to set 192.168.0.0/24 to area 0.0.0.1, but nothing changes.
RTA
Current configuration:
hostname ospfd
password zebra
log stdout
interface eth0
interface lo
router ospf
network 192.168.0.0/24 area 0.0.0.0
line vty
end
RTB
hostname ospfd
password zebra
log stdout
interface eth1
interface eth2
interface lo
router ospf
network 192.168.2.0/24 area 0.0.0.0
line vty
end
RTC
hostname ospfd
password zebra
log stdout
interface eth3
interface lo
router ospf
line vty
end
16 Replies 16
Hi Eugen,
Quagga is a linux routing software which configuration closely resembles IOS and that supports RIP, OSPF and BGP
http://openmaniak.com/quagga.php
Regards.
Alain
I see, thanks, similar to gns3. Learn something new everyday, but unfortunately I forget as easy
Eugen
