Simulating two 8-port switch using VLANs
active.hub2
Frequent Visitor
Frequent Visitor
I have a router platform with STP enabled on it.  If I connect Router.Eth2 and Router.Eth3 to a single 8port switch, router blocks one port.  If I connect to two separate 8port switches, both of them are in forwarding state.
I am using one Cisco SG300. I am trying to simulate the above case using VLANs.
My requirement is to satisfy the following conditions:
1. When I connect, Router.Eth2 to port 3(VLAN2) and Router.Eth3 to port 5(VLAN2), Router.Eth2 and Router.Eth3 should be forwarding.
2. When I connect, Router.Eth2 to port 3(VLAN2) and Router.Eth3 to port 4(VLAN2), one of the Router.Eth2 and Router.Eth3 should be blocked.
In SG300, Spanning Tree state 'Disabled', STP Operatin Mode as 'Multiple STP' and 'BPDU handling' as filtered.  When I did connection (1), Router.Eth2 and Router.Eth3 are in forwarding state.  In connection(2) also, Router.Eth2 and Router.Eth3 are in forwarding state.
In SG300, Spanning Tree state 'Disabled', STP Operatin Mode as 'Multiple STP' and 'BPDU handling' as flooding.  When I did connection (1), Router.Eth2 and Router.Eth3 are blocked.  In connection(2) also, Router.Eth2 and Router.Eth3 are blocked.
Can someone help me in making necessary configuration on SG300, to make my requirements meet.
Thanks in advance.
uv.
0 Replies 0
