single switch from stack not showing in CER
dckhovey1
Level 4
Level 4
    I have a switch stack consisting of two C2960S-48TS-L's and one  C2960S-24PD-L. It has been givin a single IP address on the Management vlan.
The issue is that in Cisco Emergency Responder, after adding the stacks ip address, only the two 2960S-48TS's show and not the 2960S-24PD, which has our phones connected to it. This makes it so the ERL only applies to the two 2960S-48TS's and not the 2960S-24PD, which is the only one with phones.
any help or suggestions is always appriciated.
Teressa Corson
Does anyone have a suggestion for this issue?  I have the same problem.  My hardware is different.  I have a stack of 4 WS-C2960S-48LPS-L switches.
All of the ports on these switches were showing in CER until recently when the switch stack went down.  A colleague brought it back up but the master switch ("Switch 1") had corrupt flash and had to be reconfigured.  "Switch 3" then became the master switch.  The ports that I do not see are those on Switch 1 (G1/0/1-48).
I have deleted the switch stack from CER and re-added it.  No change.  I have verified that the SNMP string needed for CER to query the switch is in place.  Does anyone have any other ideas as to what I can check?
Thanks.
sh hardware
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.0(2)SE, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Sat 28-Jul-12 00:42 by prod_rel_team
ROM: Bootstrap program is C2960S board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(55r)SE, RELEASE SOFTWARE (fc1)
HHS-HZNF3E-1 uptime is 3 days, 5 hours, 59 minutes
System restarted at 08:47:38 EDT Mon Jun 23 2014
System image file is "flash:/c2960s-universalk9-mz.150-2.SE/c2960s-universalk9-mz.150-2.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-48LPS-L (PowerPC) processor (revision E0) with 131072K bytes of memory.
Processor board ID XXX
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
208 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : F4:7F:35:C1:83:80
Motherboard assembly number     : 73-11907-08
Power supply part number        : 341-0393-02
Motherboard serial number       : XXX
Power supply serial number      : XXX
Model revision number           : E0
Motherboard revision number     : A0
Model number                    : WS-C2960S-48LPS-L
Daughterboard assembly number   : 73-11933-04
Daughterboard serial number     : XXX
System serial number            : XXX
Top Assembly Part Number        : 800-30937-03
Top Assembly Revision Number    : A0
Version ID                      : V03
CLEI Code Number                : COMGZ00ARC
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
     1 52    WS-C2960S-48LPS-L  15.0(2)SE             C2960S-UNIVERSALK9-M
     2 52    WS-C2960S-48LPS-L  15.0(2)SE             C2960S-UNIVERSALK9-M
*    3 52    WS-C2960S-48LPS-L  15.0(2)SE             C2960S-UNIVERSALK9-M
     4 52    WS-C2960S-48LPS-L  15.0(2)SE             C2960S-UNIVERSALK9-M
Switch 01
Switch Uptime                   : 3 days, 4 hours, 30 minutes
Base ethernet MAC Address       : 58:BF:EA:CC:38:80
Top assembly part number        : 800-30937-03
Top assembly revision number    : A0
Version ID                      : V03
Switch 02
Switch Uptime                   : 3 days, 4 hours, 42 minutes
Base ethernet MAC Address       : F4:EA:67:9F:C0:80
Power supply serial number      : LIT16111EGK
Version ID                      : V03
Switch 04
Switch Uptime                   : 3 days, 5 hours, 59 minutes
Base ethernet MAC Address       : F4:7F:35:DF:3E:00
Version ID                      : V03
Configuration register is 0xF
In case someone else runs into this issue.  There is a known bug for CER versions 8.5(1) & 8.6(1).  It is fixed in CER version 9.0.2.
https://tools.cisco.com/bugsearch/bug/CSCua66336
The workaround is to make the first switch the master.
