11-20-2009 07:07 PM - edited 03-06-2019 08:40 AM
what is the difference between bootflash and slot on the following comand;
Switch#
copy source_device:source_filename slot0:target_filename
Or:
Switch#
copy source_device:source_filename bootflash:target_filename
11-20-2009 07:13 PM
Cfajardo,
The bootflash is the onboard memory module (DIMM) which is not removable. Slot0 is the CF card slot.
HTH,
Brandon
11-20-2009 07:38 PM
hi brandon,
are you referring to the sodimm which by default comes with 512mb when you said dimm?
thanks
11-20-2009 07:44 PM
No -- I apologize for the confusion -- The SODIMM is the Supervisor's RAM memory. However, I believe there is another compact flash memory module located on the Supervisor that is a similar style flash module, although I can't find documentation. I might be wrong on that one. If you pull out the Supervisor, you should be able to tell which module is the DRAM and which is the Flash, assuming there are more than 1 module.
If you can't afford to pull out the Supervisor, you can add a compact flash card and set the Supervisor to boot from the CF card.
11-20-2009 07:55 PM
-so does that mean the bootflash is not an FRU?
thanks
11-20-2009 08:04 PM
I'm still looking, but most likely not an official FRU -- I can't find any part numbers other than CF cards. So if you are having problems with a SupV and you have a SmartNet, then I would work with TAC to arrange an RMA.
If you're on your own however, then I still think there is a replaceable flash module, but it would be a matter of finding the right part. See the attached pictures from an Ebay auction for a WS-X4516 -- one of those modules is clearly a Flash module.
11-20-2009 08:29 PM
this are the part numbers i got from the link of the link youve provided..
64 MB MEM-C4K-FLD64M
128 MB MEM-C4K-FLD128M
11-20-2009 08:31 PM
I think those are both CF card part numbers
11-21-2009 09:04 AM
we aggreed before in one my post that the
-64mb builtin compact flash is the bootflash
but in the pictures you posted i couldnt see any compact flash...
