SM-X-ES3-24-P Code upgrade
brikenav
I am trying to upgrade the code on SM-X-ES3-24-P, which is sitting in a 4331 router.  I am able to get the c3560e-ipbasek9-mz.150-2.SE6.bin code in flash and change the boot statement.  When I reload the module to bring it up i get:
Error: hardware not supported by firmware.
       Try loading newer software instead.
       System Resetting...
Then a boot loop starts.  I have to do a recovery procedure on it to break in and have it load with the default code to bring it back online.  That default code only brings the SM module up and can't do any configs.    Any ideas?
Oleksandr Y.
You might need a Universal IOS instead of IPBASE, this is a SW after all ... I hope it makes sense :)
