11-06-2019 10:49 AM
i have created vlan10 for data in my small business switch SG300-10P and i make untagged to GE1 and save it , but when i reboot the switch it's goes to default and i found GE1 is tagged in VLAN10 .
11-06-2019 11:20 AM
Not familiar with SG300-10P series switches but make sure to save you config before rebooting.
11-06-2019 02:01 PM
When using Web-based configuration then by clicking "Apply" on any window the changes are stored in the Running Configuration ONLY. To preserve the changes (after reboot) the Running Configuration should be copied to the Startup Configuration. To achieve this please click "Administration > File Management > Copy/Save Configuration" and select the source/destination files (Running Configuration/Startup Configuration) and then click "Apply".
Good Luck!
Best regards,
Antonin
